... does anyone know an OH Kit is?
OH = OverHauling kit (you'd think for that kinda money it'd include the $70 bushings.)
and the VCG, is this really your biggest problem right now, are they leaking so bad that your coils are getting soaked and your LS is misfiring and your engine is getting covered in oil, the problem is so bad and it must be done ? or .. wait, they are just sweating a little like millions of cars out there and the Steelers just thought they could squeeze that out of ya as well.
forget about the VCG's for now, it's not priority, neither is the brake job, pull the wheel and have a look, most likey lots of pad/rotor still left.
You gotta remember, they are there to UPSELL, plain and simple!
Thread jack (kinda) - But this is very interesting to me.
... Shortly after my visit to the dealer, I reset the battery and haven't seen the "E" since - nearly a year ago ...
Right on, as I've been saying, without drivability problems, reset and fresh filter/fluid,
see where it goes from there as opposed to immediately dropping a new trans in.
Just pointing out it's resetting the PCM by means of disconnecting from the battery for a while. (not able to reset a battery but you knew that.)
