Follow-up (because I hate when no one does that).
So, the car spent two days at the dealer. First day they diagnosed a P0605 ROM error, and took a transmission fluid sample. Service rep said you may need a new PCM and / or a trans. A-tech said the transmission fluid smelled burnt and had particulate in it. Also could not duplicate issue on test drive. WTF. Second day I told them to just re-flash the PCM. BTW because my car is an early production 03 and apparently there is no TCM so everything is controlled by the PCM. After the re-flash there were no codes present. They then asked if I wanted them to drop the pan. At that point, I said NFW. So I picked the car up, drove it for a couple of days without incident and put it through the drive cycle again for good measure. Picked up 6 quarts of Mercon V and a filter. Put the car on a lift (lucky enough to have access to one) and it appeared that the pan was never dropped. Cooler lines up front were a little wet but not dripping and tight. It appears that the previous owner had a flush done but I assumed not the filter. Dropped the pan, fluid not burnt, no particulate, and a small amount of “fuzz” on the magnet. Douched pan out, put new filter in, and put about 5.5 quarts in to the proper fill level. Shifts better and still no incident of the 5-4-5 problem. At the speeds that I drive on back roads, depending on load, it still sometimes hunts between 4 and 5, but, not slamming.
And yes, $250. (bend over) So, who do you trust? My ScanGauge did not pull any codes as well as an SCT and some others I’ve hooked up. So what good are they if the CEL is not flashing? And this code should have tripped the light. Unless you have the $20k ford scanner how does the average ‘Joe’ diagnose this ****?? Very disappointing when you have the ability and skills to make the repairs.
I love the car, but, it’s got it’s hand in my pocket so far.
Is it fixed? Jury is still out on that…. I’ll post again in a month or so….
