MBertrand98
Hi guys, so I recently replaced my transmission solenoid after 1-2 gear started shifting rough and 3-4-5 was a delayed shift, it was not throwing any codes or that E symbol at the time I had the trans flushed after I saw the condition of the fluid. Well now after doing all of that, the exact same thing is happening but now I have the E symbol, and these check check engine codes: torque converter clutch circuit electrical, shift solenoid A, shift solenoid B, Shift solenoid C, pressure control solenoid A Control Circuit low,pressure control solenoid B Control Circuit low, what the hell is causing this it almost sounds like the solenoids not plugged in but I made sure it was pretty tight, also it does take a few start ups for those codes to turn on if that matters, I really need some help with this!
