chris2523
93 Mark VIII
ey Chris, the CD stated 13.9 quarts, above you say the book states 12. Wondering if there is a difference between 1st and 2nd Gen's?
there is a difference, but its not gen 1/2, its pre/post 96.
in 96, the cars got a slightly deeper (dimpled) pan to help combat starving the pump uphill or around sharp corners.
(this can be added to early cars by purchasing a 96+ pan and filter.)
the 96+ spec was revised to 12 liters (12.8 quarts) according to Ford books (i always thought 12 quarts, but this does explain why 13 always worked better).
not sure about the 13.9 spec, i have never seen that one before.
I'm also looking at the JMOD and with drilling holes - how do you keep all metal fillings out? I would think this is a re&re and done on a tool bench once out of the M8?
that is correct, you remove the valve body from the car, and disassemble it to get the seperator plate out. then you drill the plate, and reinstall everything.
