TSB Information Request - #18320 - VIBRATION FELT FOR A FEW MILES OF DRIVING
rallyusa
Lilburn
If there is anyone on here that has access to full TSB details for the LS, I have a request for one. I have the exact same issue as listed on this page. Specifically "VIBRATION FELT FOR A FEW MILES OF DRIVING AFTER PARKING."
Can anyone post the full TSB for this, or at least tell me what is involved? I can't find much information about it.
TIA
I just looked in alldata and dont see anything listed for that, below is the list for 3.9, also looked under 3.0 and did not see any
2004 Lincoln LS V8-3.9L VIN A
Vehicle Level Technical Service Bulletins All Technical Service Bulletins
Information
Number Date Title
09-12-12 06/29/2009 A/T - Loss Of 2nd/3rd/5th Gears/Ratio DTC's Set
08-16-5 08/18/2008 Engine - Drive Belt Snap Noise In Extreme Cold
07M07S1 05/20/2008 Campaign - Ign. Coil/Valve Cover Gskt. Warranty Ext.
07N09S1 05/20/2008 Campaign - Ign. Coil Cover/Wiper Motor Brkt. Warr. Ext.
07-12-3 06/25/2007 Restraints - Control Module DTCs, Associated Fault PIDs
07-5-8 03/19/2007 Battery - Battery Eye Function/Charging/Service
07-4-3 03/05/2007 Interior - Leather Wrapping On Steering Wheel Is Loose
07-1-7 01/22/2007 Steering - Mercon V(R) Fluid Usage
06-25-15 12/11/2006 Body - Aluminum Body Panels - Corrosion
06-25-13 12/11/2006 Parking Assist - System Inoperative / DTC C1983
06-21-19 10/30/2006 A/C - Heater Core Electrolysis/Leakage
06-18-16 09/18/2006 Engine - Reman Engine Head Gasket Identification
06-15-8 08/07/2006 Keyless Entry - Keypad Diagnostics
06-5-16 03/20/2006 Steering - Squeaking Noises When Turning Steering Wheel
05-26-12 12/31/2005 Parking Assist System - System Inoperative/DTC C1983 Set
05-22-9 11/14/2005 Electrical - Low/Dead Battery/No Crank Condition
05-22-8 11/14/2005 Ignition System - Coil-On-Plug Misfire Diagnostic Tips
05-21-8 10/31/2005 A/T - 5R55S, Delayed/Harsh Reverse Engagement
05-18-7 09/22/2005 Electrical - Wiring Soldering/Crimping Service Tips
05-16-2 08/22/2005 Ignition System - Engine Misfire/DTC's Set
05-16-8 08/22/2005 Navigation System - Poor Map Zoom Operation (Canada)
05-16-11 08/22/2005 Restraints - Seat Belts Slow to Retract
05-14-4 07/25/2005 Engine Controls - MIL ON/DTC's P2106 and P2135 Set
04B22S3 05/27/2005 Campaign - Additive For A/T Fluid
05-9-3 05/16/2005 Interior - Repair/Paint to Match Instructions
05-3-1 02/21/2005 Engine Controls - MAF Sensor Diagnostic Service Tip
05-3-10 02/21/2005 Restraints - Seat Belt Stop Button Service
04-24-14 12/13/2004 Engine Controls - General PCM Programming Procedures
04-24-5 12/13/2004 A/C/Audio - Defroster/Antenna Grid Diagnosis/Repair
04B20 12/01/2004 Campaign - Rear Seat Latch Owner's Guide Update
04-22-13 11/15/2004 ABS/TCS - Warning Lamp ON/DTC's C1145/C155 Set
04-18-16 09/20/2004 Interior - Climate Controlled Seats Turn Off/DTC's Set
04-17-4 09/06/2004 Engine Controls - MIL ON/Lean DTC Service Tips
04-15-7 08/09/2004 Lighting - Moisture in Reverse Lamp
04-13-7 06/28/2004 A/C - Rear Window Defroster/Antenna Diagnosis/Repair
04-13-2 06/12/2004 A/T - 5R55S Harsh Upshifts
04-1-7 01/26/2004 Audio System - AM Band Radio Interference
03-23-2 11/24/2003 Body - Exterior Mirror Glass/Motor Service Tips
03-18-1 09/15/2003 Keyless Entry System - Service Tips
03-17-2 09/01/2003 Interior - Headliner Falling/Unattached in Rear
© 2012 ALLDATA LLC. All rights reserved.
Terms of Use
TIA
TSBs aren't numbered that way. With very few exceptions they are X(X)-X(X)-X(X). I don't see any TSB referring to a vibration. Sounds like classic flat-spotting to me.
TBH that's what I thought too, but I seem to remember reading somewhere a while ago that there was a TSB that involved doing something with the steering shaft assy. However I could be totally wrong.
The flat-spotting does make sense however, and now I'm wondering if I have the original tires on my car or not, 8 year old tires could definitely be the problem. Does anyone know what the OE tire was for this car? I have Continental's I believe, but I will double-check later.
Thanks
Thanks
Michelin on the 17" and Continental on the 16".
Age doesn't have as much to do with flat-spotting as does aspect ratio. Anything with a ratio of 50% or less will flat-spot; the lower the ratio the greater the chance of flat-spotting. The flat spot should go away after 5 or more miles.
OK thanks, this is the first car where I have had this low of a profile on my tires, so it makes sense now. I have the 17" stock chrome wheels so the fact that I have Continental tires means they've at least been replaced once during it's lifetime.
As long as the flat-spotting is the explanation then I'm not worried, it's just that after I came across that TSB I was a little worried.
Thanks everyone for the feedback!
