Lonnie
I agree, you can wright about any table values you need and the ECU will handle most anything, but for a TT setup you better have a very competent tunner!!
Whats your boost per turbo, waste gate, and BOV, injector size fuel pressure static and constant? 1 MAS or 2 in series, did you compensate for the MAP, Is it intercooled? how about engine mods to handle it, a stock 4.6L DOHC Mark VIII's internals will hold about 450 crank horse power.
I just want to save you allot of grief if you bought one of those cheep TT setups on E Bay for $339.
Setting up TT's on a Mark is very possible, complicated and expensive..........
Very good points. I've dealt with a few of those that went the Ebay route and it was very painful for the customer and costly. The EEC IV Mark 8s are a totally different animal when it comes to tuning. Without the high dollar data logging equipment that most tuners won't spend to have you can't possibly tune one of these correctly. Those that attempt will basically just piss in the wind since they can't log the real needed parameters to properly tune. They will try and use the dyno to log the rpms and if it has an analog output they can get the MAF volts. Then you add the wide band O2 for the a/f and that's all they use. That may be ok for some and they will accept that for a stock or mild setup but it's not the right way. I wouldn't trust anyone that would try this with any type of force induction. Then you have the automatic trans, most tuners only know Mustangs and deal mostly with manual transmissions. They are lost when it comes to tuning an auto the correct way.
