I decided to fill in all the holes that are found in the engine bay of this platform and with that, I realized I need to fire up the weld I got for Christmas years and years ago that I never touched. It's your average Harbor Frieght Fluxcore box but, that should be more than enough for this project. I had some spare metal laying around from other projects so I decided to make a few test passes to see what I can do and how bad I am.
I have no real idea what Im looking at here. I know the splatter is just a by product of Fluxcore stuff and, i know I was starting to get decent beads to lay down but, past that. It looks like Greekaphilgy.
First attempt:
Attempt 1 was to weld the bent steel the the steel plate. The top weld was my most recent on that attempt and, where I turned up the speed the wire. Clearly, the top weld was the best one there. The weld to the right was a test past to see how the wire speed increase actually worked when applied to metal.
DashGutting-5606 by
Jason Bacon, on Flickr
DashGutting-5608 by
Second attempt:
Cut out a small piece and weld it to create a little wall. That didnt turn out well, trying to weld that little piece with no means of holding it up resulted in burning through (lower left corner) and just really sloppy looking welds. Not being happy, I took a 5lb mini sledge and bent it over and as you can see, it held. Then I tried to weld it down while filling the gap that is obviously left with that type of bend. After that, I just decided to make a few lines that resemble letters or snakes.
DashGutting-5616 by
DashGutting-5620 by
Musical inspiration provided by:
[video=youtube;YA6SRE2JQBk]
yq_lmliMw[/video]
