ILLS
Well the PVC sure is an... interesting idea.
Other than that, two words:
Take pictures.
I think what Medium is trying to say in a polite manner is that, "Running PVC under the car for boost is a dumb idea." I wholeheartedly agree.
It will hold the pressure but that is not the only stress it will need to withstand. It will also need to withstand the undercar heat and cooling cycles, weather, road debris, continuous chassis flexing and so on. PVC is not designed to withstand all of those stresses. It is meant to be used in an immobile location and protected by a wall or concrete so that it cannot be cracked or crushed. I can guarantee you that within 1-2 months you will have cracked that PVC pipe and be chasing boost leaks like crazy if it doesn't just altogether fall apart.
Do it the right way and just run some aluminum forward. It is light and not terribly expensive.
As a person who has many years of experience in this stuff I have one continuing recommendation for those who are new. Don't do it unless you are at least going to do it right. I am not saying go balls to the wall for the best stuff money can buy, but at least do it right. If you think that you might be cutting a corner then don't do it. Tiltedhalo, you knew you were not doing it right otherwise you would not have put the comment in there about "getting looks for this". Sometimes that feeling right there is a good guide to stay away from certain things. My post is not meant as any sort of flame or jerk comment in any way but I think you do require a little bit of a reality check when it comes to doing things the correct way. Best of luck man.
