Ultimate Set of Wheels for the Mark VIII!!!!
holy wheel gap!
those tires dont look like 245/45-19s either.. there isnt much sidewall there.
but otherwise, i kinda like them.
Looks pretty much the same as Mike Shultz wheels, without the gap. Those look like 45's because Mikes look the same but without the gap and Mikes are 18" BOZE. Even with those tires, you could sensor lower enough to remove that big of a gap. I'm sure some air shock and rear air spring mods would be required. Mikes wheels have the rivets and are three piece also but his studs are on the inside and not on the outside. I like them ok but don't like the studs showing and having to keep them clean. Be good for someone that has a nice brake setup to show off.
Here is the potential look on a Mark less the gap lol. His fronts are 40's and rears are 35's I believe. It's just one of those wheels that you have to like the look of... I wanna say his tire size is Toyo Proxes T1R 255/40ZR18 & T1R 285/35ZR18
Not bad, Stack. That wheel gap is crazy tho. I'm sure it'll look better (fill gap better) on an LS :D
I would recommend starting a new thread, with a different title. LS guys might be reluctant to click when they see "Mark Wheels"...i know i was.
GL dude
They aren't 45 series:-/ I just assumed
275/30-19 rears
245/35-19 fronts
Bridgestone Potenza re960's
Needs rears now that I mounted them
GL dude
Thanks! I'll start a new one per your recommendation:-D
Oh and this was just a test fit... I'm not running them. Just wanted to get pics up for those who wanted to see em!
My car is on springs so no lower!
Here is the potential look on a Mark less the gap lol. His fronts are 45's and rears are 35's I believe. It's just one of those wheels that you have to like the look of... I wanna say his tire size is Toyo Proxes T1R 255/40ZR18 & T1R 285/35ZR18
I think these would have looked CRAZY good on the murder mark to show off the 13" brakes all the way around... If the mm was within finishing for me I'd keep em
holy wheel gap!
Prob cause they're 245's on a 9.5" wheel. My old 19's came with 225/35's on a 8.5" wheel and it looked similiar(a little worse) to these. Put on 235/45 and it filled them out alot better.
nah, its just cuz they aren't 45 series.
275/30-19 rears
245/35-19 fronts
yeah, that sounds about right.
cool wheels though. bit pricey for my tastes.
