Lets get this to the top so people can see it.
Haha, you must have felt the ora because I was typing the last responce as you bumped this!
B) There will be no camber adjustable plate on the top because camber is adjusted at the wishbones not the coilover itself.
Not to pleased about that. Our rear camber is not adjustable
Im going to want less than a 2 finger gap im at that with my set up now. I wanna tuck tire a bit.
So that is one thing I will want/need to purchase these
I'm cross referencing this with the "lowered measurements" thread to see what people have and want. Its hard because it has to be tall enough work with stock and aftermarket wheels, 16"-19", but also low enough to be an advantage over the the aftermarket shock/(cut) spring combo. We'll get this as versatile as possible. Nothings in stone for the specs yet.
Both of these design adapations will lower the price, but will not affect coilover performance in the slightest. We're also working on having the coilover run all the way from stock height to 2 finger gap from tire to fender; with valving to run from close to sporty stock feel to stiff.
how much are we talking? I would be in if its around $1000. Even at 1350 I would consider it (it would just take me longer to get it all together).
start saving now.
I personally think a lowering range of 1-3.5 would be ideal.
If people want a stock height they should keep stock suspension.
I just dont want to purchase these, install them, and lower them all the way and it look like I still have my cut eibachs on there. I hate seeing the top of my tire just how I am.
Same. Just dont wanna invest if i cant go lower then where we are now.
Any idea on what adjustability the shock will have, like single tool adjust, remote reservoir adjustability and so on?
Also not sure if I missed this or not but is this a damper only or will these be coming with dual rate springs and such
