theophile
Well my car is fixed!
Got a used FEM off EBay and took it to Ford to reprogram. My steering is back like it should be now.
I was wrong about the BRN/GRN wire being shorted to ground. It goes to pin 2 in the FEM which is a ground so it should be shorted. This is an error in the Ford shop manual trouble shooting the VAPS.
What all did the dealer need in order to be able to flash the new module? More specifically, did they need the car? I was hoping I'd be able to just bring the two modules into the service department with one labeled old and the other labeled new. But when I finally got a human being at the Ford dealership to answer the telephone, the service manager told me that I would have to bring in the car and the new module would already have to be installed in it. I said that there is a risk that the car might not be driveable with the new module if it came off a car with a significantly different configuration, and she suggested I have it towed there.
That sounds completely absurd to me. On the other hand, I know that the body control modules function as a network so I suppose it's possible that somewhere in the flashing process it might be necessary for the tool to be able to see the rest of the module network. But I had been assuming that the FEM just has a flash RAM chip and that you can hook up the module on a bench and read/write to the flash RAM using some proprietary tool or scanner. In fact, I was hoping that the dealer might not even need the old module, but could determine what configuration to flash to the new module using the barcode or serial numbers on the label on the front of the old module.
Speaking of which, does anyone know whether there is a way I could use the information on the label of the new module I bought to determine the VIN or configuration of the car it came from? If it was configured the same as my car, I might just try swapping the modules and seeing if I can get lucky.
