yes mine is actually leaking on the passenger side of the car, i have a 2003. im actually in process as we speak on repairing it, i took the valve cover off to check to see what the problem is, the only problem that i see is that the o-ring seal on the valve cover is what is causing the leaking problem, i took the valve cover off and checked the part, the part is good.. so i looked around and can't seem to find just the o-ring so i am gonna seal it up with some black RTV and that should fix the problem, hopefully, but taking the valve cover off was a B***h my hands are all cut up and there is very little room to work with. but the best and easy fix would be a little bit of rtv now i gotta get to work so i can get the wife's car back together.. let me know how you make out
