devunn
Hey guys.. the car has been running pretty well since I replaced the vcgs and the coils until now. I can't listen to any music!! It's :q:q:q:qin terrible! Started my car yesturday and turned on the radio and nothing. Turning the knob for the volume does nothing. Normally when you turn the knob "Vol" appears on the display and you'll see bars either going up or down depending on if you're lowering the volume or not. Now all that happens is "Vol" appears on the display and no bars follow. I have removed the radio from the dash and checked all connections to it...everything appears to be fine. The controls on the steering wheel have the same result. Anyone have any ideas? I doubt it could be a fuse but I'm going to check that. I never realized how important music was until now. The system is completely stock, I have not installed anything.
