Jiovanni12
I want to stag my ls. With 20 x 9 in the front and 20 x 10 in the back how would that look. Need help please let me know what you think.
the only reason to go with a wider tire out back is that if you have enough power that your normal size wont hook up anymore...
Don't you mean understeer?Or to induce a little oversteer......
just plain sick....You mean like this?
Dat Stagger by Schmidt Photography, on Flickr
Lincoln LS by Schmidt Photography, on Flickr
IMG_6205 by Schmidt Photography, on Flickr
You mean like this?
Th LS already has (according to the suspension guys) some understeer dialed in. The wider tires on the rear will push the front around the corner quicker as they should have more traction due to their larger contact patch.
The staggered setup of the Jag S Type R works with the LS with 60mm offset both front and rear. That setup has 8" wide fronts and 9.5" rears. TSW wheels come in staggered sizes but not sure if the 8" fronts can be had in the 60mm offset. There are many forged wheels that can be ordered with custom offset but they are very expensive.
8" wide @60mm doesn't sit flush with the fender. Some people got spacers to fix that.. something like 20mm?
You mean like this?
