Psychostang
I opened up my cap to the a 3/8" square drive. Came off no problem. Whoever designed that cap with the 1/4" square drive should be shot!
scott9050 said:1/4 inch on bottom, 3/8th adapter in the middle, 1/2 adapter on top with a breaker bar= no problems.
Calabrio said:Don't get too excited, I didn't have a very hard time stripping out that little quarter inch hole... Rather than apply any steady force, I just give it a couple quick taps and it opens. Prolonged force just ended up damaging the top of the plug.
Penetrate it with some oil and just give it a couple hard, fast smacks on the handle with your hand.. that's worked for me.
MrWilson said:yeah, well your way produced a striped cap...
what do i do now? Its stripped real good.
Not really because you can go very slowly instead of using a shocking force. I've done it on 2 different cars and they came off easily with no damage done.Calabrio said:But applying the leverage associated with a breaker bar would certainly have mauled the top.
94m5 said:Allright guys.......
Ease up on the attacks, and name calling. FYI, I weld a 13 MM nut to the top of the cap if I ever have problems taking it off. This effectively ends all problems with a stripped out hole.
