chris2523
93 Mark VIII
new oil pressure sending unit and oil filter adapter gasket.
my oil leak is getting bigger...
then hunt down a trans fluid leak. i think its at the radiator side tank, so i'm just gonna bypass it. already have another cooler on it.
then trans fluid temp sensor install along with a fluid change and new gasket. the trans pan is wet, so its leaking there or at the dipstick o ring. probably change that too.
after that, it may get the K member dropped for a new oil pan gasket. i will have to see how much it is still leaking after the new opsu and gasket.
