Okay, this just in:
The melting point of Carnauba wax: 183 degrees F
the previous numbers regarding the surface temps of paintwork were taken after 2 hours. Who knows if after 8 hours it would be hotter, or hot enough to melt the wax on the vehicle.
A wax compound (the waxes/solvents together) do evaporate. That's the process of wax though. The solvents act as carriers, to evenly distribute the wax across teh surface. After that, the wax cures, which means that the solvents evaporate, leaving only the wax behind.
Now, a wax COMPOUND can have a melting point as low as 100 degrees F. But the cured wax's melting point is MUCH higher.
Sealants are better for durability, as their melting points go into the 300 degree F range.
