R
rocket5979
Guest
driller said:In my case, 15 pounds x 2 = 30 pounds rotational weight
30 x 8 = 240 lbs static weight
240 / 100 = 0.24 seconds ET reduction
That would've been nice, but I doubt I actually achieved that. I suppose it might have been a tenth or so. But I figure my worn suspension is costing me in the launch so much it possibly negates the theoretical weight savings.![]()
You are right. There are other factors that come into play when swapping rim/tire combo's out. Stuff such as tire surface contact patch and traction come into play too, which though a car may net a little more MPH in the 1/4 due to faster acceleration it may not gain too much ET because of lack of traction off the launch. Analyzing time slips before and after the change will help a person diagnose what their achievement or problem was, and (better yet) why.
That was the case when I raced my Explorer last week. I had lighter rims and tires (with less contact surface) but I had to feather the launch soo much that I only ended up getting only .10 better when the weight diff was good for more than .25 seconds. In a situation, where the vehicle would be able to get sufficient traction in both the before and after scenario's, the rule of thumb stated above would be fairly accurate.
