Black_Sunshine
I recently have been battling some overheating problems, and also not having any heat. I ended up replacing the dual climate control valve, the aux water pump, and while I had it all apart, I went ahead and changed the serpentine belt, main water pump, 2 idler pulleys and the serpentine belt tensioner.
Since I did all this, the car still overheats, and the interior heat system seems to barely work.
So, all of that is weird, but it gets worse... Today, I was running the car, trying to see if i could bleed more air out of the cooling system, in case it is air locked or has an air bubble in the heater core, or somewhere else.
I raised the driver's side of the car up a foot while running, to make that the highest side of the car. I was getting some air to come out, but the car again overheated, so I shut the car off...
When I started the car back up, after it cooled, it ran very badly. As-if I had a couple of cylinders not firing. No misfire error code. I lowered the car, and tried to start again. Same thing. Running very rough, as if its misfiring, but again, no errors. I put it in gear to move the car into the garage, and engaging the transmission killed the car. Now, when i try to start it, the starter cranks, but it won't start.
I'm at a loss at the moment. Aside from overheating, the car had otherwise been running fine. It had overheated several times before. The oil still looks clear. Have I destroyed a cylinder? Does raising one side of your car and running it cause problems? Help a brother out....
