ford nut
Local nut case
Get it from rock...it will be at your house next day.
why did you put projectors in it YUCK!!!!
well i got my new head unit in the mail today, putting the system together right now, still gotta get my components, and my JL's from terry. got this amp from him already, and the deck off egay. i also bought a blanket for the 97!!!
Drove it to the track and beat the snot out of it.
And??
Those 12 second hubs didn't work.
Best run of the warm March opening day was 13.8 @ 99. :sleep:
Sixty foot times were ALL 2.0x.
A lot of issues to sort out.
The alternator is not charging at idle, so I had to "idle" in the lanes at 1500 rpms to keep the battery up. That didn't do much good for engine temps.
Several down times at the track, but still managed 12 runs.
Need to sort out the tune and get the boat anchors off the front, plus a lot of homework.
ok where do I start?
Last Saturday- 4 wheel balanced, 4 Wheel Alignment(required outter tierod end) Oil Change, Ordered rear struts from Arnott, Ordered front Airbags/Struts from American Air..
Sunday, - 8 plugs replaced, 6 actually went in. Replaced all 8 wires.
Monday- bought Mirror from Jim.replaced 2 plugs and was able to get them to screw in.. Had CEL on I would assume for the miss I now have in the engine.. CEL went away on its own, then the Door ajar alert on display... Sprayed down all hinges and door pins.. Cleared message....
Tuesday, cleaned throtle body,bought new Serpentine Belt, Front left caliper, and strut rod bushings for frame....
Wednesday, looking into the headlight resurface.
Thursday will be out shooting Darts,
Friday - CAR day.. will spend all day putting in parts hopefully all parts will show up.
Saturday take car back to alignment shop so I can it redone due to strutrod bushings...
Enough done?
I will update the pics with the completed images as soon as I can find the damn camera!
i thought you said you polished them hid housings bill? those pics dont look polished, are those before pics?
Spent all day polishing the 8 rib tensioner by hand
While I had the stuff out I went ahead and did a quick polish on the blower and the fuel rails.
Still deciding what to do about my alternator, wiring, battery situation. uuuggghhh
ok update******
I got the new suspension parts in and installed them friday, rides almost as smooth as new, I guess you have to take into consideration that the rims are not perfect and cause a little vibration at 90+.. also the tires arent new anymore so I bet the wear in them might be a bit of it.. anyway, got that done, regapped the plugs trying to find the miss, and restored the headlamps.. fixed front brake line to caliper, was leaking, new brass and tighten down good.
oh yea, continues, Sat day of rest.. Sunday back to the car again. now I have a pronounced miss, and I have the CEL on. IAC error and lean bank 1..
Today I dived in head first literally...
I got the bolts out for IAC, found the TB gasket ripped up, took an hour to track down new one.. then the fun started.. putting in the new IAC, first off its a top mount connector differs from original. second I think I cross threaded the bolts back in... I did get it tight but,I guess it will be a complete intake system removal to get at it again.. oh yea replaced all the autolites with Bosch Plat 4 plus's. car idles good but I cant run her tonight to test I have to wait until the morning on my way into work to see how it is... wish me luck!
