what's the real deal w/ Tranny fluid replacement?
i think vanilla is better, it cleans up better
I dont care if my ice cream is SHINY or not... and I dont wash my ice cream very often.
How does it clean up better?
no water spots?
or does just "hide the dirt" unlike chocolate?
ok then, III or V?
since stated that the original in the Mark is III.
93-97's had mercron III from the factory
98's had mercron 5 from the factory
presumbably because in 93,94,95 and 96 there wasn't mercron 5..yet.
They used the "best that was available at the time"..
at the time mercron 3 WAS the best.
You put what you want in your trans, at 125K on mercon III I have no issues.
Why should he add mercon V fluid to his existing mercon III fluid? That makes no sence, they are not compatible. I don't understand why in the world you are telling him to drain ALL of his trans fluid out & totally replace it. At 127K with no prior service it is a bad idea.
If he had mercon V fluid in there now, then I could see dropping the pan & putting in 4 new qts of V in, But don't mix the two or drain all of your fluid out.
If the trans had been serviced on a regular basis then I may have a different recomendation & the V swap would be just fine. It's not though.
I never said that the trans wouldn't work on Merc3. All I said is that Merc5 was specifically invented, designed, and engineered for the 4R70, and specifically to solve certain common problems that the trans has. Given that this fluid was invented because of and for the trans that you have in your car, why would you not run it? Last I checked, Merc5 was 20cents/qt. more than Merc3. Assuming you get every drop of trans fluid out, and allowing plenty for spilling a couple quarts on the floor, at 16qts that comes to $3.20 difference to go with the good stuff.
As for the rest of your post, first off, they are compatible. There is no reason you can't add merc5 to a trans that currently has merc3 in it. Second, the reason I am telling him to drain all the fluid is because ALL the fluid has 127K on it. When you change the oil in your car, do you only drain half the oil out? What about if you accidentally miss an oil change, would you then be hesitant to ever change your oil again? You do know that sludged up engines can hide the sounds of a damaged bottom end, and occasionally when you change the oil in a car that is seriously overdue, it develops a knock, right? Your logic with the overdue trans service is the same as telling someone who is overdue for an oil change that they should never change their oil again and just leave well enough alone.
At this point, with the dirty fluid, his trans either has a problem or it doesn't, just like an engine that has dirty oil either has damage from it, or it doesn't. If the trans does have a problem, then changing half the fluid might expedite its death, and changing all the fluid might kill it even faster. If it doesn't have any problem yet, then the sooner you can get ALL of that dirty worn out old fluid out of there and replaced with new, the less chance you have of the trans developing a problem.
Also, I would like to point out that the situation of the fluid change making the problems worse is not anywhere near as common as people think. In 5+ years of working as a mechanic, I have done countless trans services, both flushes and fluid and filter changes, and in all that time I have only had it make the problem worse on one car...ONE!
You are very likely to shock the trans. The 2 fluids are not compatible per ford itself. Engine oil & trans fluid are totally different & can't be compared to each other. But then again, someone is always the expert even if they cost you a transmission in the process.
Can you mix the 2 fluids? Ford says no, Maybe you can but it's not recommended. That's not the point I'm trying to make though!
Should you do a total fluid swap with 127K with no prior service? NO WAY. Do it in stages. every 6 months or so. You obviously know nothing about automatic transmissions or fluid.
I am done arguing this point, If you want to do it, then do so. It's not my car.
First of all, don't say that I don't know what I'm talking about. I know quite a bit about automatic transmissions. I've rebuilt my share of them over the years, and I completely understand how they work. I also take pride in my profession as an auto technician, and I don't mislead people or spout off things that I don't understand. If I tell you how something works, or why something works, then I'm telling you from my own understanding of it, not just rehashing something that I heard somewhere else. If you want to disagree with something I have to say, that's fine, but don't try to discredit me as "obviously knowing nothing about transmissions". Instead you should explain why you think I am incorrect about something. You haven't done that, you are just repeating the things you have heard from a bunch of other people. You have told him "just use what it says in your owners manual", and talked about "incompatible fluids" and "shocking the transmission", both of which sound to me like the things people are usually told by a shop that doesn't want to do a trans service on a trans that is already slipping. Maybe I'm wrong and you know more than I do about the design of transmissions and fluids. Maybe you know even more than the engineer who designed the transmission, but you haven't come off that way, and the impression I got is that you are repeating as fact things you have heard other people say. Seeing that, I feel an obligation to inform this person who is seeking advice exactly what I think, and exactly why I think it. If you think I'm wrong, and you want to help him, you should do the same and explain to him the benefits of doing it your way and precisely why I am wrong. What you should not do is announce that I don't know anything about transmissions. First, that simply isn't true, and second, it doesn't give understanding of anything to this person who asked a question and presumably want to understand why the answer is what it is. Now that that's out of the way...
I have never heard anywhere before anything from ford saying you can't mix merc5 and merc3. If that is the case, then why on every bottle of merc5 does it say that it can be used as a replacement for merc3? Why does the ford TSB say that merc5 is the new replacement for merc3? I think what you are thinking of is the old typeF fluid, which was not compatible with the dexron/mercon, and would swell all the seals in the trans and cause it to fail. That doesn't happen mixing merc5 and merc3. In fact, the only difference between the 2 fluids is that 5 is a synthetic version of 3, and it has some additional friction additives.
Also, like I said, if there is no damage to the trans at this point, then changing all the fluid sooner will be a good thing. The only way changing all the fluid would be a bad thing is if the trans is already damaged from the old fluid, and if that's the case, changing all the fluid will only expedite the inevitable. There isn't going to be any "shocking the transmission" by changing the fluid. Either the clutches are wiped out and the friction material floating around in the fluid is keeping the car moving, or the clutches aren't worn out in which case putting in all fresh fluid, with the proper additives for those friction materials and that transmission, could only help. If the clutches are worn out, then slowly changing the fluid isn't going to help you because once all the old fluid is eventually out, your trans will be just as bad as it would have been if you drained all the fluid out in the first place. It might actually be worse because for that 6 months while you had half the new fluid and half the old fluid, all the additives and friction modifiers in the old fluid would have been used up already, which could cause the friction discs in the trans to wear out faster.
This concept of changing half the fluid exists for one reason and one reason only, and that is that it isn't convenient on most cars to change all the fluid. 4R70s have a drain plug in the torque converter, but most transmissions don't. In a case like that, people don't want to do work twice, so they either drop the pan and change the filter with the 4 or so quarts that come out that way, or they leave the pan and filter alone and just do a flush. The best way to do it is to change the filter and all the fluid. It is no different than doing an oil change. As the oil goes through the engine, the additives break down and the oil carries dirt and other particles through the filter. If you change the oil and don't change the filter, the new oil will pick up all that filth that is stuck in the filter. If you change the filter and don't change the oil, you won't have the proper additives in there, and the new filter will get clogged up faster because the dirty old oil is going through it right away instead of clean new oil. The transmission fluid and filter are no different. Additives in trans fluid break down. As they do so, the fluid becomes less able to prevent wear in the trans. The fluid also gets "dirty" with the friction material that wears off the clutches. If you change the filter and 1/3 of the fluid, then you still have all that fluid without the proper additives, and the new filter is going to get dirty much faster because the particles being carried through the dirty fluid will get caught in it instead of starting off with all clean new fresh fluid. Similarly, if you do a flush and change all the fluid, but you leave the old filter, all that new fluid is going to get contaminated when it goes through the old dirty filter. That's why the right way is to change all the fluid and the filter at the same time.
nsjuice, if you have any more questions about this, feel free to PM me.
unsubscribed
Like I said, You obviously don't understand how the whole shocking the transmission thing takes place. Would you like to write another novel?:p
Thanks Blend. and everyone else for the heart to heart.
I can proudly say, I understand now! As should the next person who runs into this dilemma.
Thanks guys.
Topic can be closed!
Damn...very good topic.
Blenderhead...your replies are very informative...thanks! I have similar worries as nsjuice and been pondering the very same thing so this thread is awesome.
