04_Sport_LS
If you want to try a shortcut fix... rather than using friction tape,,, go to orange depot or the blue box,,, and pick up one of those electrical splice kits that has the very large heat shrink tubing. It should shrink down enough to snug up on the sway bar. Uswe more than one layer if needed. Keep in mind though,,, that this is just a temporary fix... and you will eventually need new bushings or a complete sway bar replacement.
Ask yourself... how many times you want to screw around with this. Your own answer at that point,,, should tell you how to fix the problem.
