You can 'grade' the ROI - but there is a positive ROI - that is all that matters.
There is absolutely no way you can no that. You are simply asserting that as truth. And considering all the factors
against it, that is
highly unlikely.
And once again - you were the one that ill defined 'create wealth'.
No. The creation of wealth is pretty well understood unless you are uninformed or intentionally don't want to understand it except in the context of your little world view.
No, the government doesn't "invest". That is a bad term to use. It bastardizes the term to use it like that. The government is not looking to make money or to grow their money.
And in every example you cite, there is no literal return on investment. At best it is, again, metaphorical. A distinction you clearly are incapable of making.
What happens is the government basically makes a resource that is
completely autonomous. That means that the actions of that resource are not dependant on the government. Weather or not that resource ends up making wealth or leeching off of society is in no way determined by the government.
The same is true of all the other examples you cite of the government
facilitating the creation of wealth. In each case they either create or provide a resource that the
private sector then used to create wealth. And it is an economic fact that the private sector distributes and utilizes scarce resources as efficiently as is realistically possible.
And you are wasting mine, and everyone else's time by trying to backtrack and redefine how you specifically view wealth being created.
I am not "backtracking". What is happening is what always happens. You talk in circles and create a web of distortions, half-truths, etc. Then I have to come in and clean up the mess. Then you come back and do the same thing. It becomes a war of attrition.
You were the one that stated that the government does not create wealth - now you are expanding that to include factoring in opportunity costs?
I am not expanding anything. I am simply expecting any claim of some entity creating wealth to make economic sense the same way that the fact that the private sector creates wealth makes economic sense.
You are trying to ignore certain standards and basically get a double standard injected here; another patented
foxpaws false premise (tm). Now we know that you will not shut up. What's that propaganda technique called? Oh yeah, the
Big Lie.
Talk about moving goalposts... the government creates wealth through investing in education.
And here you are equivocating again. Reason be damned!
The only question is does the government create wealth? Not how much, or could it be done better, just does it?
Now you are attempting to lower the bar for your standard which is based on something which doesn't happen. The question is not simply does the government "create wealth" (to which the answer is "no"). The question for your specific example is does it create wealth, on the whole; in the aggregate. If the opportunity costs (wealth destroyed) exceed any supposed "wealth creation" then no wealth is created. And with every government initiative, that is the case.
You were the one that added the section about how the private sector could educate children better - it doesn't even belong in this discussion.
If your claim is to be at all economically realistic then it must confront the issue of opportunity costs. Instead you are trying to avoid confronting it...
So your claim only holds weight in some utopia based on wishful thinking. Many ideologies have tried that in the real world and all have failed to various degrees.
And again, you know, if you argue opportunity costs, I am going to have to assume then that you do believe that the government is creating wealth
You are once again, attempting to
DECEIVE!!
When I first brought up this issue of opportunity cost it was under the auspices of accepting your premise
for the sake of the argument. I in no way genuinely accepted that premise. But it is very telling that you would try and weasel that in like that.
But, the military is still part of the government shag - and can't be excluded from your blanket statement.
An exception to the rule doesn't disprove the rule, it confirms it. And the military itself does not create wealth it facilitates the private sector creating wealth (in a very efficient manner compared to any and ever other government organization).
And who do private companies make money off of - customers. That is how wealth is created.
You really have no clue how wealth is created, do you? You are simply grasping at straws. This statement alone, shows your utter economic ignorance.
If you were actually conversing in good faith, I would gladly take the time to explain how wealth is created.
It is odd shag, you obviously understand the fact that the person or entity with the money creates wealth for others.
But this book. Read it and get back to me.
Amazon.com: Basic Economics 3rd Ed: A Common Sense Guide to the Economy (9780465002603): Thomas Sowell: Books
In the Polanski thread you understand that the people that back his movies are creating wealth for Polanski
I said no such thing. Either you are basing that on your severe misunderstanding of economics and specifically concepts like wealth creation, etc. Or you are intentionally working to distort me to try and "trap" me. Either would not be out of character for you.
No, shag indirect or direct was not implied in your statement.
Well, given your utter economic ignorance, maybe I should have spelled that out. I was assuming some basic level of knowledge in economics which clearly doesn't exist on your part.
I haven't redefined or mischaracterized anything shag - I have used your exact quote. I am sorry if you weren't very good at stating what you 'really' meant.
Again, sorry I assumed some basic level of knowledge on your part.
FYI: the mischaracterization doesn't have to be intentional or direct. It can be something that is implied or inferred in what you say. Your ignorance of economics here is a big part of that, it seems...
The private sector is where the wealth 'happens' but how it is created shag is a whole different thing.
How does wealth "happen"?
Also, while you are at it, answer me this...
We know that if the government was a non-entity in the economy, under a pure capitalist system, wealth would be created by the private sector. They do not need the government to create wealth.
If there is no private sector, can the government create weath? All the examples you cite are of the government facilitating the creation of wealth in the private sector. How does the government, alone, create wealth (no private sector involvement of any sort)?
