nasty!!!! i bet that tunned box makes that thing hit!!!Heres my set-up. Custom box with a 12" DC Audio XL on an AQ 2200 = pure sex!! Complete access to the spare compartment. Link in my sig if you want more info.
Heres an underconstruction pic.
nice and simple steupMine:
Nick, may I see a pic of your center console? That sounds very interesting.
nasty!!!! i bet that tunned box makes that thing hit!!!![]()
Here are some shots
First picture shows with the grilles on, i had the Alpine 6Disc set up originally so it had speakers there already, smaller than the 3.5's. To fit these I had to remove the A/C ducts that run down the console to the vents in the back of the console.
Second picture is without the grille
Third picture is the subs, dont mind the trunk mess, I keep alot of crap in there. Used to have 2 12" kickers but I had no trunk, This box fit al the way under the rear deck to the rear seats. Leaves me some trunk to use
4th pictres is the amps, they are mounted to the rear seat backs in the trunk
5th picture is Tweeter mounted in the A-Pillar
I had a shop build the box for me about a year after getting my LS. Told them I had to be able to get the spare out and how I wanted the amps set and they did a great job. It is a simple build. If I had to do it again I probably would have enlarged the actual box the sub is in. I think it is a little under spec but it sounds great and I didn't lose all my trunk space with a factory built dual 12" box. I left my other Type R in the closet in case I fried this one. Still going strong though. I have plans to turn it into a home theater sub eventually.
Good luck to the OP with your build.
That's not too bad, actually. Mine is made of 3/4" Birch plywood (from my custom cabinet supplier), carpeted with carpet from partsexpress, and the aeroport from partsexpress as well. I probably have $100-125 just in materials.
If you do it piece by piece you can build something like this 3.7 cu/ft box that holds 2 12's and the amps and cap and takes up minimal trunk space.
It is held in by gate latches and can be removed in a minute using the handles as it weighs 125 lb with the Cadence subs
Link to when I built it 3 years ago.
[URL="http://www.lincolnvscadillac.com/showthread.php?t=54583"][url]http://www.lincolnvscadillac.com/showthread.php?t=54583[/URL][/URL]
:bash:
I was thinking about getting this box myself. Does anyone have any info on it? Does it sound good? Is it worth the buy? etc.
http://www.ebay.com/itm/2000-2006-L...es&hash=item58902a1dd7&vxp=mtr#ht_2532wt_1396
i have a 12 w7 in ported box, hifonics amp with 2ga wiring, infinity reference highs, and pioneer avh-p3200bt headunit. all installed myself. also installed rattletrap xxxtreme through the whole trunk and rear deck. the 12 w7 had a puncture in the cone and when i called jl they told me that if i didnt wanna send in and pay for repair i could use goop to seal it. lol. so i did and its held ever since.
