why dont u sell your lincoln and get a damn mustang. what you smoking over there if i race with a 2000 ford gt i would blow the mustang off not just the doors
Ohhhhh okay noob... I'm not sure how many engines you've built or performance cars you've owned/wrenched on, but given your statement above... I'm guessing your experience with performance would be rather minimal.
Anyhow, since you're now saying you'd destroy a 2000 Mustang GT... Here ya go killer... (I'll even give you the Non-PI 98 specs)
2000 Mustang GT V8 Coupe:
Curb Weight: 3241 lbs
Horsepower: 260 @ 5250 RPM
Torque (lb-ft): 300 @ 4000 RPM
1998 Mustang GT V8 Coupe:
Curb Weight: 3269 lbs
Horsepower: 225 @ 4750 RPM
Torque (lb-ft): 290 @ 3500 RPM
YOUR 2000 Lincoln LS V8:
Curb Weight: 3692 lbs
Horsepower: 252 @ 6100 RPM
Torque (lb-ft): 267 @ 4300 RPM
So lets go over this... Your LS VS 2000 Mustang GT:
:::Advantage-Mustang GT :::
Weight: 451 lbs lighter
Horsepower: 8 Horsepower More
Torque: 33 lb-ft more
:::Advantage-Lincoln LS:::
NONE
Here... How about a slightly more fair race: Your LS VS 1998 Mustang GT:
:::Advantage-Mustang GT:::
Weight: 400 lbs lighter
Torque: 23 lb-ft more
Horsepower: 27 Horsepower More
Hate to break it to you, but against a 2000 GT... unless the driver weighs in at about 500lbs and happens to be asleep; you'd get your rear-end handed to you
As for against a 1998... Closer race, but the GT has you on torque and comes in 400lbs lighter; you only have a 27 HP advantage, which is not enough to make up for your torque and weight deficit. That means equal drivers... the LS still looses. Make it a Gen II LS and you've got a close race.
Numbers and physics don't lie my friend; come to terms with how unbelievable a claim like that really is. We're all LS owners here, we know what our cars can... and cannot do. You don't have some magic 2000 LS that rolled off the assembly line with 100 more horsepower. Take my advise; next time you want to talk about what cars you could "blow more than the doors off", research the numbers those cars. As for mustangs, if you can find a factory stock 95 GT or older... you'll have a winning race. But good luck; most 5.0L GT's that are in good shape and still cruising the streets are very likely to have something under the hood that will send you back to the stone-age.
As for why I don't have a mustang... simple, I've got a boat, F-150 and LS... I've got no more room. I'll be adding both a Mark and 03 Cobra to my inventory within the next 1-2 years... just as soon as I find a place with a huge garage, or room to build one.
