Why I don't drive rice.
lets look at all the evidence here.
1)even if the gas peddle stuck it would have or (should have )gotten stuck at 1/4 throttle 1/2 at best. this :q:q:q:q:q:q:q obviously floored it up the street to go thru a fence,garagedoor,rear garage wall, and the neighbors fence. boy was flyin.
2) i have throttles stick on my regals and even my t-bird but i was and am smart enought to know the bes idea ever would be turn the key off DUH and hit the brakes, stomp the clutch in is is a manual trans no? or shift into neutral or worst case park ok so you shatter your trans but its better than destroying some guys house and what if god forbid he was in the garage or his kids were in the yard.
bottom line is the kids a jerk and got just what he deserves and the fact that it is a kid in a ricer is only more proof positive of high performance cars with low performance drivers.
Eric :tmi:
I saw the post on the board that this orginated from....
http://forums.nasioc.com/forums/showthread.php?t=658311
So how did one who posted this here, describe a ricer, find it??? Visiting Rice Boards??? :p j/k They apparently have an accelerator recall or something... the board is my friend's he told me about it last week...
It's a small world after all.... It's a small world after all....
ok i just called Beltway Subaru here in brooklyn and spoke to the service manager and one of there techs and i asked them exactly what this clip recall was and i quote" the accelerator clip recall is is a clip that connects the Cruise Controlto the throttle linkage if the clip should fail it would only render the Cruise Controlin opperative. so i guess our boy here just cant drive like i said before. and as for how this thread was found i agree someone must have a interest in these cars too. hell i like the evo but i wouldnt own one
oh and p.s. you fix your heat?
Thanks to your tech article, and I gave u props in my thread, I have heat, probably temporary... you and I are gonna split a case of :Beer one day when I get ready to re-do my hand controls and fix my telescoping/tilt wheel at the same time and u can check my wire-tie crimping job then... the only confusing thing was when I opened the glove box I immediately realized u took pcitures from "below"
And also my friend agreed that that kid just is an Id10T behind the wheel.
Id10T error happens between the wheel and the seat.
thanks for the love but i must admit i did not write the heater motor repair article only the steering wheel 1 i do have and article saved here about strengthening the blend door actuator its a little frankensteiny but i know iw will never break.
Eric
hottweelz said:
per item, earn a good $4.50
for the whole bag of stuff i need to fix the arm if i even told you how i intend on doin it you would believe me but i can tell you 1 think for sure my heat and ac works fine.
