why so lean
PATS will flash for remote start some of the time, other times it actually works.
if it is the kind of bypass where you stick a key inside of a box, then the bypass's antenna ring needs to be adjusted (assuming that it is getting a good status/GWR signal and that the module itself is not failing) the position is very finicky(part of the reason I don't like to use them), if its not perfectly positioned, then it may not work a lot of the time. a flashing PATS light means that the system is not seeing a valid key.
for the other 2 keys, the light is off, it just won't crank
:confused:
well that is very odd, if the key is valid, the light should come on solid then go off, if the key is not valid, then the light should flash. if there is anytime the light doesn't come on at all, then that is a different problem and it sounds like you are losing power somewhere.
