I really don't like to be spoon fed anything by either side. I do like to look at things for myself. Here, it is easy -numbers are readily available. Rather than use any 'group' such as Heritage or Brookings, why not start by looking at some numbers yourself? I can then see going to some biased source after wards and seeing what they say about it. But, when you don't have an independent baseline to judge anything on, how are you going to know whether what they are touting is even close to being correct? Shag, you might have a tendency to 'believe' Heritage while I might have positive leanings towards Brookings, but what is wrong with a little independent thought?
So do you have ADD or are you just being dishonest?
If you really want to to not be "spoon fed anything by either side", then I linked to the numbers originally published by the government for the various years in question in post #35.
Of course you are smart enough to realized that the numbers are hard to analyze in and of themselves even for someone who has the time to do that; most people are not statisticians. Any working american is going to have to turn to a secondary source.
What you are clearly doing is dishonestly and decietfully attempting to raise the burden of proof by demanding primary, "unbiased" sources.
You have to use secondary sources so you must look at their credibility to determine if what they say can be trusted. Seeing as you cannot win that argument, you are wanting to throw all secondary sources out. Sorry, despite your best efforts, Heritage is credible.
You are also assuming that any secondary source will mischaracterize the information. That assumption alone makes your conclusions in the quoted section fallacious non sequiters.
But if you truely believed that assumption, then you would not be posting at all in this forum, because we all have very strong biases and are really not in any way primary sources. You are clearly still on a crusade to get Heritage thrown out of the discussion by any means necessary.
And your line about not wanting to be "spoon fed anything by either side" and that you "like to think for yourself" is laughable. You clearly accept most any liberal talking point without first examining it's credibility. The only thought you ever seem to apply is in the defense of those mindless (and logically indefensible) talking points. If you wanna demonstrate that you "like to think for yourself" then how come you never seem to apply any critical thought to the talking points before you accept them?
That is one of the big differences between conservatives and liberals. Liberals accept illogical talking points without examination and never even seem to comprehend true conservative counterpoints (only strawman mischaracterizations spread by other liberals). However conservatives and other non leftists (most of which where liberals, or more liberal, in their younger days) have reasonably considered both the liberal talking point and the conservative counter and, after applying some critical thought, rejected the liberal one, and usually accepted the conservative point.
You are a fool if you take any hard position without first understanding the issue and applying critical thought to the various positions attached to that issue. Yet that is clearly what you (and most liberal voters) do constantly.
And yes, you do have to compare FDRs numbers to something - otherwise how do you know if they are to be considered a success or a failure?
I stand by my statement, You don't need to compare the two presidencies to determine what the original subject of this thread is; the failure of stimulus spending.
FDR's numbers cover the highest unemployment recorded (by any standard) in US history! By implication, it is compared to all other unemployment levels recorded throughout US history. To single out Reagan is unneccessary and, unless you can give some reasonable explaination for making that specific comparison (and you haven't yet), dishonest.
Reagan never pushed any type of spending stimulus, so to compare his record is to make a false analogy, as the subject of this is thread is the effect that a government spending stimulus has on the economy. There never was any spending stimulus under Reagan. Any attempt by you to say there was some sort of spending stimulus (and you have done so before) is a dishonest mischaracterization, and you know it.
Oh, and if you look I am using only FDRs numbers from 1933 to 1940, before our involvement and build up for the war. And, certainly Reagan was building up for a war during most of his administration, not one that was ever fought - but the build up was there.
FDR was building up for war long before we entered WWII. When we officially declared war, instituted the draft and started rationing, that was when we effectively created a war economy. Reagan never had that.
Ah, yes, look at post #41 (your post) in your first quote that you pulled from my post #40 "Do you have some other ways we should be looking at this data?" my words... I was really interested in other ways to slice and dice this...
Yes, look at post number 40....You still tie it back to Heritage and anyone who reads this thread can clearly see what you are doing. Trying to spin it only hurts your credibility even more.
In post #36, you turned on a dime from trying to smear and marginalize Heritage through their representation of the New Deal and it's effects on umemployment to trying to smear and marginalize Heritage through Reagan and comparing the two.
You really want to get Heritage thrown out, and are willing to throw out all secondary sources to do that. Is your ego really that big? Can you really just not admit that you were wrong about Heritage and it's reporting of unemployment during the great depression?
Or are you simply working to muddy the waters enough so that no conclusion can be drawn about the effect the New Deal had on unemployment?
Either way, please keep posting as you are further proving my point that liberals cannot argue accept through dishonesty, deciet and/or smears.
Thanks again.
