97SilverLSCcobra
Does anyone know how to find out what year an engine is bye the numbers off of the block? and Whether a 1993 engine with all of the stuff except the heads swapped on it from a 1997 engine will work in a 1997 LSC if I have the stock original harness for the car itself and all I will be using is the lower half and the heads? The reason I am asking is because after I bought this car the guy tells me that it is a 1993 engine!!! But it was remanufactured bye Ford in 2000 so I am a little worried that I am about to run into some problems now!!! Let me know what you guys think!!! Also does the 1997 engine have the hose that comes from the back of the waterpump and runs under the manifold to the lines mounted on the back of the engine? or Is that something from the 1993 engine that I am going to have to change around? I have seen some pics of a 1997 engine with the manifold off of it and I didnt see that hose that my engine has!!! Getting worried now!!!
