when my wipers quit
I have an 01 Ls-8 , I had changed the wiper blades and a short period of time went by , a week or two , and my wife who mainly drives this piggy bank , said one day , by chance did you put the wrong wiper blades on my car , I replied , Nooo why do you ask , well when I turn them on , they make a full wipe or two then stop up on the glass and won't go any more or go to park if I turn them off , BUT , if I stop the car and restart it later , if the switch is in the park position the wipers will go to the bottom of the glass , and OH , buy the way , when I arm the alarm , the horn sounds like it just died , well having a good back ground in electronics , I started to trace the wiring from the trunk at the battery , checking all the fuses and retightening all ground connections , the wire harness goes from the trunk forward along the RS rocker panel to the RF floor side kick panel , more relays and connections , checking for anything loose as I went along , it leaves there and goes to the starter motor , and proceeds up to the Right Front corner of the Radiator support and Right Side fender inner skirt , a whole mess of relays , fuses and such , checking every thing as I go , NOW Right in back of the Right Head Lamp Assy , there is a welded stud { ground stud , with I believe 2 or 3 wires on it }, IT WAS LOOSE CAUSING THE PROBLEM , hope that helps you all Frank T
