Winter frustration...
Sticky doors & Trunk
Silicone spray is excellent to lubricate any rubber type seals. Brake fluid is the best cleaner. Don't get brake cleaner on the paint or wipe it off immediately! Wipe windshield wiper blades with break cleaner & see a difference. Liquid graphite or dry graphite is an excellent preventative against locks freezing. Use before they freeze!!! I have lived all over the USA from Calif to New York to Fla. Winters are wet or dry depending on where you are. The north has dry cold most other places it is a wet cold most of the time. Living in snow 13 miles south of the Canadian border for 20 yrs. & 16 yrs in Calif from San Diego to Truckee yor exsperience alot of weather!
try running the defroster for a few mins before you leave it parked out in the cold to remove moisture from the air. the warm/moist air in the cabin will cause condensation in and around the seals. then the condensation freezes wherever it 'pools'. wd40 treatment described above will definitely help the cause... also stop your excessive powersliding to avoid dirt/water buildup ha
