WTB... rear shock hardware..
96_Lincoln_LSC
Bristol
I have a need for the metal hardware that actually sits on the to of the rear shock. I need replacement rubber and all of the metal disc's that attach the shock to the adapter plate for our cars. I ONLY NEED ONE SIDE. the nut came loose and the strut came free, causing the loss of the lower half of the hardware.
PLEASE if anyone has this and can get it to me ASAP I would appreciate it. I have brand new struts installed and cant afford to have this banging around everyday.
Thanks
Bill
I don't know for sure if the 97/98 mount is the same, but I have THESE for sale. I also have the two metal washers that go with each side, which I'll throw in. I don't have the nut however.
i beleive there was a diagram on tccoa.com of the rear upper metal plate..Shows you how big it is were to bend ect...Go to a metal fab shop and hand the diagram to them..i cant see it costing that much.
I'm actually looking for the washers.. since I just got the rear struts, the two had brand new mounts for the body.. do I really dont have a need for the mounts, just those 2 damn washers... lost the one on the bottom as it fell off when the strut came out. the top nut unscrewed and the strut came loose from there.
Thanks DLF...
If you tell me the outside diameter and the diameter of the hole in the middle, I can make you some washers really quick at work....
Let me know.
Thanks DLF...
2 washers? I thought you just lost the bottom from one side.
Tell me exactly what you need.
Here's what I have.
You can have what you need for $10, and I'll ship them in a USPS priority box, so you'll have them in a day or so.
PayPal to dlfraleigh@comcast.net
I ran them through the bead blaster.
Let me know which of these that you want.
