you could ground the door trigger wire, then the computer would at least think the door is closed. the dome light would no longer come on, this would also effect the alarm system, and the radio wont shut off for ten minutes after you turn the car off. not too mention that driving around with a door that wont shut is just plain fukcing retarded. i think you should just fix the problem instead of hiding the symptoms.
