My $300 LS build
Looks much nicer. Now remove those radiator upper supports and paint those up.
btw: Your outlet pipe and Thermostat housing are on their way out soon. Take notice of the browning on the exterior. Means they are worse off on the insides. You can bolt on a cheaper direct fit all aluminum JAG housing instead.
If you're not going the CAI route possibly think of an air box mod.
Lincoln Tech - Lincoln LS Performance
When Im done this will be the blackest car you've ever seen, hence the name "stealthlinc" aside from under the hood, also red calipers, and red Lincoln badges front and rear.
IMO red just goes better with the all black stealthy look, than blue or silver would
That's right, the Batmobile,
a 1955 Lincoln Futura was also black with red.
