thethirdeye88
i am debating on tearing down my engine and rebuilding it...balanced and bluprinted, higher compression dome top pistons (maybe 11.5 to 1), port and polish the hell out of the head, 3 angle valve job, lighter valves and better other pieces, custom ground cams from a very reputible source or maybe even custom cams, no regrinds...2nd gen intake, ram air, box it off, cut a hole in my hood...
tear the tranny down check the gears and other stuff, i want a shift kit...are they available?...they shoul be, we use the same 5r55n thats in the GT's...they just wont swap....i figure there is one out there...if you know, let me know...lightweight flywheel, thinking about a stall converter, but dont know how well it will apply for my use...3200 if i can...i need a new tranny linkage assembly too...mines acting funny and getting sticky...
i want the 8.8 pumpkin out of a t-bird or cougar...so i can run some 3.56 gears...or if there was something in between the factory 3.34 and 3.56 that would be perfect....
can i get bigger throttlebodies?...
also going to get an SCT Xcal2...and dyno tune the whole setup...
wanting some custom tube headers, high flow cats, bosch O2 sensors, X-pipe, long good resonators and turndowns to let the exhaust out at the diff...
im thinking about having ILLs do this for me, since he does have a speedshop and is familiar with the car considering he did his own turbo install...
basically do a complete runover of the car, there are various other things that need to be done and all will probably be at the same place...replace what needed...also want strut tower braces for the front and rear, can someone get them?...what about subframe connectors/braces...and depending on how the car comes out a roll cage may be installed...it is definitely being considered...
well thats my idea...sounds pretty good to me...expensive yes...very...but its a good route...plus there is already a supercharged, turbo, and bottle fed landspeed LS...
