FNG81
I did some research and found how to do the COP replace... Removed the intake etc. I did all that, I even had valve cover gaskets and rings Incase oil was seeping into the plug wells but all was good. Button that all up and move to replace the o2 sensors....
We live in an Emissions County in Texas so that was the reason for fixing the car and getting the CEL off plus it was missing at random times.
Crawl under the car to start pulling o2 sensors and the previous owner had pulled the V8 and put in a V6. Since he didn't live in an Emissions County there was only 2 o2 sensors after the little cat and no upstream sensors. You could see where they welded new pipe and I assume just "deleted" the wrong ones "dumbass**".
So my question is can I just run new wire to the pcm and weld in bungs on each side?
If anyone has a wiring diagram "wiring for dummies" friendly would be awesome for the o2 sensors or any other suggestions that would be good also.
I'm really not even sure which ones he deleted, he might have an upstream on one side and a downstream on the other... Who knows! Passenger side had a "green" cover and drivers was "grey/white" but that's just the sensor wire so no way of telling if it was the factory upstream/downstream pcm wire.
Any help would be appreciated. The new MC COP and NGK plugs fixed the running issues I just have to fix the hack job on the sensors. I'll upload the printout from the obd codes as well
Thanks!
