CyrusMainTea
nvm got it
, just waiting to get tuned
I read here that i can put a check valve between the intake manifold and the air assisted injectors, just temporarily until i get different injectors. Now i was wondering where that line is on the Gen 1 v6? and which way to place the check valve?
i just need a proper tune probably. Torrie is not responding atm... Anyone else have the ability to tune for me?
I don't think the V6 has the same air-injected injectors.
You sir are correct. The first gen V8 is the only LS that has the air-assisted injectors. To the op, I understand the budget build and fact that you're trying to save money but you are going to end up spending far more on this than you would if you went with a decently reliable set up from the beginning. There's the old adage you get what you pay for, in this case it is definitely rings true.
Nothing says class better then a purple waste gate sticking out from under a Lincoln. (maybe you said something about moving it in the video, at work no sound)
I hope it all works out for you. You need to somehow get the whole system up higher cause its gonna rub and get tore off.
Keep at it! Cool to see someone just go for it.
holy crap this looks scary man... Melting your bumper, no filter, snowy conditions, low hanging...
All of this seems like asking for disaster, but props on the work. Would love to see it cleaned up and running with the tune soon!
+1 on how are you oiling this thing?
Sesame oil I would imagine. It will work better with the Chinese turbo
