CyrusMainTea
lol i just laughed my self
, ill try some of those tips to track down the boost leaks. I think i know where there at anyways
All that rubber needs to go away. Those connections either need welded or reinforced silicone. Those clamps need to be swapped to T-bolt clamps. I understand this is a budget build, but this is where you can't skimp. Those home depot couplings won't hold, neither will those clamps under boost. You will end up blowing off one side or another every time.
curious as to why the piping didnt just run down where the factory exhaust was?
since the car came with dual exhaust, the easiest thing to do would be to combine the two exhaust pipes into one (thicker pipe of course) right at the back of the motor since they have to be combined at some point to go into the single turbo, and then run the boost side piping right next to it where the now removed other exhaust pipe was, that way you wouldn't have to worry about any pipes hanging low.
That's a nice stainless setup on that car. I's that a pinch in the exhaust at the O2 sensor? Shadow? Intake charge should be as far away from the exhaust as possible, so the above pic is a great example. Silicone and T-Clamps, who would of thought...
at what cost? having the boost side piping hanging too low puts it at a way higher risk of getting snagged on something and getting a hole ripped into the pipe (or just having the pipe get ripped smooth off) a two and a half inch (or bigger) pipe ran along the bottom of the car under the lowest point of the car is just asking for it, you would be much better off running both the exhaust and boost piping down the tunnel and up out of the way. as that example is a FWD car without a trans and drive shaft tunnel, there is much more room under the LS and the pipes dont have to be ran so close together that they are almost touching. the few degrees of heat soak you will get is more than worth the cost to protect all of the plumbing. if your really that worried about heat soak, you could also just heat wrap the exhaust piping, there is more than enough air flowing under the car while it is moving, and then just let the FMIC do its job.Intake charge should be as far away from the exhaust as possible
actually remote turbo setup only provides partial cooling compared to having an intercooler, and while some motors may be able to handle boost better(probably because they were designed for FI from the start) with the LS having such a high CR motor to begin with, you would have to be crazy to think that the pressure drop is not worth the much colder air, the turbo will easily make way more pressure than this motor will ever be able to handle without going crazy with all of the internals (again we are talking about a budget build here ) why wouldn't you trade off some of the pressure that you cant even use to provide a much more safer setup up for the motor?but the advantage of having a rear mount is not having a FMIC setup, due to that cool air underneath the car.
if that was true, and intercoolers didn't do anything, why would they be out there? did you use intercoolers? i'm sure you did because they make a huge difference. im also pretty sure what makes a FMIC efficient is the size (surface area) and its ability to exchange heat. if you have aire that is "too hot" coming into it, you use math and science to figure out how big it needs to be to get the air charge cool enough.A FMIC is only as efficient as the air charged coming into it. If it's too hot, it's only going to be a little less hot coming out.
Hence why STS kit never would come with an intercooler.
