2000 LS Ball Joints
Ball joints wont cause any acceleration problems or engine noise...will it?
I was leaning toward my problem being ball jonts because of the noise it makes when i turn the steering wheel left and right. But i cannot see how it would also cause the accelration problems. I have it in park and cant rev then engine past 3000 rmps... it starts shaking.
Were you going to bring the whole car in and let them do the work for you? I brought just the arms in with only the ball joints in them. I had taken off the hubs at home. So that might be why it was just $20 a side.
that would be best, not to hard to take off the arms... does take a little maneuvering
i have used these ball joints on my ls and they are great...
replacement however is a pain... so if you plan on doing this make sure you have a good hydraulic press... lots of accessories and alot of patience... once you do the first the second will be a breeze
i used a long 3/4 drive extension to get the right access for the pressing
hope this helps someone
Staff online
