As joegr said, very unlikely for issues in the lower half of the engine. THE engine i put in my car was hit in the driver side valve cover. The secondary chain popped of the sprocket and we were hoping the fuel cut off switch kicked in before the valves hit. We were wrong.
The exhaust cam had split in half at the first bearing, and the first cylinder had two bent exhaust valves. I used the camshaft out of my old engine, had the valves done and other cylinders checked, it was fine. Did all the timing chaines, tensioners etc. Only reason I did this was because the engine had 37,000 miles on it and cost $400.
The engine runs solid, if the 3.9 can go through that without a bearing problem, then I'm pretty sure you're okay. Just tell them to button it up after the timing stuff, pay them, and never go back there again.
Unless you ran it on low oil all the time, overheated the car a lot, or ran the crap out of it, then the bearings are fine.
