amorgan2017
Yeah that's my issue its really tight. I can move it quite a bit I thought you had to be able to pull it down and let it kinda hang maybe wrap a wire around it. I can probably move it enough to get the 2 lower steering pump bolts but how would I remove it? And yeah I'm trying everything possible to avoid losing factory a/c charge. I did remove the steering line bracket. It was a little forward of the a/c pump, it really didn't help much. So when I gave up I lowered the car followed the line bottom of radiator left side there is a clamp on the steering hose you can pull off which I did. I'm hoping this works to get the pump out or else I have some work ahead of me. I saw all the fluid was going to leak out so I put a container down and walked away. Worst part of it all is the LS is all muddy underneath because of all the rain and my eyes have a magnetic attraction to dirt.
