Hmmm... Guess us 20 inch wheel owners can smile just a little bit.![]()
LOL. Very true. Thankfully, I am lucky enough to garage mine for the winter.
They also fit into different grooves. For instance:
Standard brakes: Works with everything
320mm brakes: Works with 17" stock rim, possibly 16" rim but unverified.
355mm brakes: Requires 18"+ rims.
This really puts the stoptech kit to shame. The front stoptech kit is a four piston 355mm rotor design but it costs $2500. With this you can get front and rear for around a grand and still get the 355mm fronts.
Everyone should invest in this if they run aftermarket wheels.
Have you seen the stock 16" wheel clearance on the calipers? It probably measures in the hundredths of an inch. There is no way the 320mm upgrade could ever clear 16" wheels.
Kumba quit being a party pooper! Lol
I think most, including myself, just want to do this upgrade for the looks. Whether braking performance is improved is secondary, although it would be nice. Even the stoptech "big brake kit" offered very little improvement over stock.
lol, not trying to rain on the parade. Just making sure someone doesn't get the wrong idea about the upgrade making the car stop better. That's all tire related first, brake related second
everything on a car ends with the rubber meeting the road. That should always be the first thing you fix when looking at the performance aspect of a car. The only other things that makes a bigger difference is the driver.
The action on a 4-piston caliper is better I think. Doubt anyone would really notice though. A lot of the benefit of the bigger brakes and all doesn't really show up under regular daily driving. Not until you go to do an emergency stop does it pop up and say hello. Even then you are limited by the rubber meeting the pavement. So if you can lock up all 4 wheels with the stock brakes, then a big brake kit won't do anything other then lock them up earlier in the pedal. That is from the mechanical standpoint. As far as the brake feel to the driver all bets are off. You might as well be arguing body kits and rims at that point. It's going to very from person to person.
For instance, say you take two identical LS. Same year, engine, trim, rims, street tires, weight, everything. You then equip one with a 6-piston caliper and a 15" composite floating rotor and stainless braided lines with some high-grade carbon metallic pads. If you were to now take these two cars and do a 60-0mph test on a dry day they would show almost identical stopping times and distances on the initial pass. A locked up tire is a locked up tire regardless of what is applying the braking force.
Now, in the same scenario, if you were doing this repeatedly in short succession you would see the bigger brakes having less fade. That's really where the big brakes shine in terms of performance. Repeated use and/or abuse.
There are two caveats to big brakes though. That being the unsprung weight and rotational inertia. I understand how those work in theory but I have never made a clear real-world connection of just how they effect things. But then again, I've never run a heat and then changed brakes before the next one. I would imagine the big thing to stand out would be the suspension reacting slower from slinging around an extra 10-pounds per wheel. I'm not sure exactly how it would translate into acceleration or stopping times from the rotational intertia. I would think that would be minimal considering the weight of the car.
Like TooManyToys stated you can actually have too much brake. I don't think that's as much of a problem with the LS since it's a pretty good size car. But a 355mm brake kit on something like a Chevy Aveo would make the brakes so finicky they would be almost unusable.
However, I think most people will do this upgrade to fill in the gap between their stock brakes and their 18"+ rims personally. They'll certainly work for that
I will probably run my current set-up until I either wear them out or start having issues with them. Then that will be my justification to spend more money![]()
So if you can lock up all 4 wheels with the stock brakes, then a big brake kit won't do anything other then lock them up earlier in the pedal. - Kumba
You highlighted his point then stated about the STR having better stopping power.
What is your definition?
If it's lower pedal effort, then you are agreeing with him. As long as the vehicle is tire skid limited, under any pedal effort within law, you are not going to improve it's stopping distance with the exception of a few milliseconds it takes to get deeper in the pedal.
except for the fact that the OEM brakes already have more stopping power than the tires can handle, as proved by the fact that if you go out and brake from 60mph as hard as you can, the ABS will constantly be activated because the tire already cant keep up with the braking force, now your adding more stopping power to the same situation, and the ABS is STILL going to be activated the whole time because nothing was done to give the car more traction to be able to utilize the extra stopping power. sure it may be a lot easier to lock up those tire now, but the same tire and the same ABS system are actually what is deciding the stopping distance.The fact is , you will stop in a shorter distance with larger rotors and bigger pads.
Smaller surface area of clamping on small brakes will not be able to generate the same amount of stopping force in the same amount of time as a larger one. Yes, it's that simple.
well mostly because the M5 already has some of the best tires in the world for the factory, so you would just be putting as good of tires on it, not to mention that the M5's tires are twice as wide.Tires are a very important component in performance of a vehicle. Extremely important. But, not as important where you make it sound like Toyota Corolla with the best performance tires in the market will stop as good as M5 with the factory tires.
Test drive a STR/XF, E550 and see what you said about bigger brakes having nothing to do with better stopping power, still has any merit to it.
I think both of you guys are looking into this brake upgrade a little too much and picking it apart. You are talking extreme conditions here, when most people don't drive around locking up their brakes every time they come to a stop.
