Dominus said:
http://www.honda-tech.com/zerothread?id=1548942
You go drop by Turbotrix and let him know how much better InlinePro is at tuning S2000's.
You and VR4 have a LOT of learning to do.
It says right in his list it has a 3 mm head gasket for starters. A thicker headgasket has nothing to do with compression though right? Then on to AEM, DSS axles and drivetrain...yeah they came stock with all that stuff. They just threw on a turbo and put boost to a stock drivetrain :shifty:
2002WRXSTi said:
I have never seen an S2000 make or do anything with it's stock compression and forced induction.
The engine is is now far from stock. Yeah they did an impressive job on the S2k but the compression is not stock with a 3mm gasket.
Dominus said:
I saw nothing refuted. Just a lot of "no way man!". Give me one single reasonable explanation as to why a disel engine would need to lower its compression, aside from engine durability. It certainly has nothing to do with the combustion event.
I have seen it plenty of times in SS pulling.
"The most extreme example is a three stage turbo diesel tractor pulling engine. The first stage actually uses twin parallel turbos to provide the required airflow. Twin parallel turbos don't provide more pressure, just more airflow. The outlet from the twin parallel turbos (low pressure turbos) feeds an intercooler and is then sent to a single intermediate pressure turbo. The intermediate pressure turbo increases the pressure further, and sends the flow to another intercooler, which then sends the flow to a high pressure turbocharger, which will be smaller in size. The high pressure turbocharger feeds an aftercooler, which then feeds the engine with up to 250 psi of boost pressure. No gasoline engine could withstand this level of boost. With this much boost, a Diesel tractor pulling engine can produce something like 5,000 horsepower from a basically stock tractor block."
The CR is dropped with custom pistons as there is no need for cold starting reliability. They have gone as low at 8:1 CR and must be started with Either if conditions are not correct. At the boost pressures they run there is no mechanical advantage to higher compression ratios.
Dominus said:
High compression is not the handicap. Poor volumetric and adiabatic efficiency is. Low compression is just a band-aid for that situation.
I found this while I was looking for the diesel turbo answer.
"Reduced Static Compression- Due to the compression of the turbo, engine compression ratio must be reduced to bring the overall compression ratio to a safe range, which will reduce charge temperatures in the cylinder. A typical compression ratio in a high performance turbo street engine is around 9:1. Non turbo engines can go as high as 11.5:1 on the street."
How are you altering this with engine managment? I have been asking this and all you come back with is prove me wrong. Were are your records and wins? Turbotrix has the record for a 4G63 engine and the shop I worked at doing SC installs still has a NHRA record that stands to this day in SS done in 1970!
Also here are a few diesel engine CR's form the manufactures because they have found that boost negates the need for higher CR's.
1982-93 GM NA 6.2L V8-Compression Ratio: 21.3
2001-up GM/Isuzu DI Turbo Duramax V8-Compression Ratio: 17.5:1
1983-88 Ford 6.9L and 1988-92 7.3L NA V8-Compression Ratio: 21.5:1
1994-98 Ford Powerstroke DI Turbo V8-Compression Ratio: 17.5:1
The manufacturers have found like racing engine builders that the amount of effort wasted on higher CR's can be better used with boost to fill the cylinder and alter the efficiency in a better way. Hence my quote as a high CR is a Handicap at this point! Not for a NA car but on a boosted car.
