Ranchero50
I'd run a controller as well. I did a Mustang kit Flex-a-lite setup on my friends Turbocoupe T-bird 5.0 swap and it worked out very well. Set the temp to 205` with a 192 thermostat, put the probe in the fins next to the top radiator hose and the fan only ran when really needed. We had to set the thermostat to 205` because it wouldn't trip back off until the temps hit 195`. We needed to stay above the thermostat setting or the fan would run all the time once it warmed up.
Other tips, we ran 10ga wire with a pair of 15A thermal overloads in parallel to allow for a 1.5x max load overload protection (18a x 1.5 = @30ol (2x15a ol)). All wired connections were soldered, never ever use crimps alone, especially where corrosion can get to them. Connections were heat shrinked and an anti oxidant grease was applied to everything.
The system has worked perfectly for several years now.
