AC Issues
if the AC lines have pin holes they would not hold pressure to begin with. I am not sure how you can pull a vacuum on AC lines with pin holes. If you were able to pull a vacuum and it held vacuum for awhile (10 minutes or more after the vacuum pump was shut off) then the lines probably do not have pin holes. Maybe just replace the o-ring at the line junctions, a hell of a lot cheaper than new lines.
Turns out new O rings will do just fine .I just want to make sure I have any and everything to do the job correct. I made to many problems before to just have things go bad again thank you .
