pagluy
Would a wheel speed sensor possibly make my front right caliper pulse like ABS when all the other brakes are just grabbing? I have had that happen to me twice when braking from higher speeds.
It sure could. If the computer believes the right front is spinning slower than the other 3 corners under breaking or locking up it will pulse that wheel (very over simplified). I'm wondering how you could tell that only one caliper was pulsing. It always feels the same to me. I just feel the pulsing through the pedal whether it is one wheel or all. Depending on the driving situation maybe it was pulsing that one wheel appropriately. If not, it likely was a wheel speed sensor or a computer glitch.
I think there is only one screw per sensor
Just wanted to update anyone who searches and has this problem later on.
I just went out and took off all my wheels and cleaned every sensor. They were coverted in dirt and grime. One even had a spider web/nest thingy on it (with a live spider! :O). I cleaned off all of that stuff and got a tool to clean inside of the little slots and put her all back together. Put key in ignition, AdvanceTrac was cleared and working again. However ABS light was still on - so I started the car and rolled about 10 feet of driving, then all error lights went off. Test drove for a good 2 miles and even reenacted the situation that made the lights come on. All is good with my LS now (For now!).
Once again to clarify. Before cleaning sensors I had 'Check AdvanceTrac' and 'ABS' Lights luminated.
What about the Gen1's??? There are no star screws on the wheel speed sensor on my 01'
I took my wheels off today to look at the sensors, my 01 ls was built in 00 and my sensors appear as follows:
fronts are the "snap on" type and look like they are a quicker change then the time it takes to pull the wheel off
the backs are different, it looks like one 9mm bolt holding the sensor cable onto the hub, runs to a bracket (this is where mine corroded and cracked away) but then it appears to connect in a really hard to get to area behind the trunk well. I didn't get under the car but I'm not sure how I'll get my hand in there.
there are two available parts listed everywhere, a snap on type and a bolt on type, so I'm assuming on mine the fronts are the snaps and the rear the bolt (but not star as some have said)
I'll post some pics later
