95DevilleNS said:
Well, lets see, we're talking about cave drawings right, basically a form of art. So use your imagination; cultures around the world have images of many creatures, does this mean that they are direct depictions of what the artist actually witnessed OR is it even the slightest possibility that the artist used his or her imagination? A drawing of a large dinosaur like creature doesn't automatically mean the artist drew from a living sketch. You must believe the Sphinx was an actual creature by your rational, since it is depicted in Egyptian art. I'm laughing my ass off at your narrow mindedness.
The only thing I've done is show you actual evidence after actual evidence that shows that evolutionists are full of it. All you've done is dream up crazy ideas to try to explain the obvious discrepancies. I get accused of being a Bible-thumping creationist, but I have not used anything but scientific evidence to prove my point. You, on the other hand, are using nothing but your imagination to try to prove yours. Who's being narrow minded here?
Me: But the scientific evidence says...
You: You're being narrowminded! I don't want to accept your scientific evidence! What if this happened?
The only people who are using their imagination doing drawings in this setting are evolutionists.
Ernst Haeckel
Haeckel advanced the "recapitulation theory" which proposed a link between ontogeny (development of form) and phylogeny (evolutionary descent), summed up in the phrase "ontogeny recapitulates phylogeny". He supported the theory with embryo drawings that have since been shown to be oversimplified and in part inaccurate, and the theory is now considered an oversimplification of quite complicated relationships. It is thought that Haeckel deliberately faked the images to get more support for his ideas. Haeckel introduced the concept of "heterochrony", which is the change in timing of embryonic development over the course of evolution.
http://en.wikipedia.org/wiki/Ernst_Haeckel
Piltdown Man
Features of Piltdown Skull "Deliberate Fakes"
Lower Jaw that of Chimpanzee?
Manchester Guardian November 23, 1953
Recent improvements in the technique of fluorine analysis made possible some of the tests which led three scientists to conclude that the mandible and canine tooth of the "Piltdown skull" were "deliberate fakes." The report of the three investigators–Dr. J. S. Weiner, Dr. K. P. Oakley, and Professor W. E. Le Gros Clark–appears in the "Bulletin of the British Museum (Natural History).
Fluorine tests carried out in 1949 says the report, did not resolve the seeming contradictions between "a cranium closely similar to that of Homo Sapiens" and "a mandible and canine tooth of simian form." Not until Dr. Weiner suggested one possible explanation–"the mandible and canine tooth are actually those of a modern ape (chimpanzee or orang) which have been deliberately faked to simulate fossil specimens"–did the investigators take what they now find to be the right track.
Experiments produced evidence that the peculiar way in which the teeth were worn down could well have been brought about by the artificial abrasion of chimpanzee's teeth.
"No doubt"
Further and more advanced fluorine tests left "no doubt that, whereas the Piltdown cranium may well be Upper Pleistocene ... the mandible, canine tooth, and isolated molar are quite modern." An analysis of the nitrogen content of these and other fossils as well as of modern bone and teeth, confirmed this result.
Other tests showed that the outer coating on the mandible and teeth did not correspond to that on the cranium. The black coating on the canine tooth turned out to be not, as the first discoverers had thought, ferruginous but "a tough, flexible paint-like substance."
"Whereas the cranial fragments are deeply stained (up to 8 per cent of iron) throughout their thickness, the iron staining of the mandible is quite superficial. A small surface sample analysed in 1949 contained 7 per cent iron, but, when in the course of our re-examination this bone was drilled more deeply, the sample obtained was lighter in colour and contained only 2-3 per cent of iron."
The first pieces of the skull to be discovered, but not later ones, had been mistakenly dipped in a solution of bichromate of potash. It was, says the report, not to be expected that the mandible (which was excavated later) would be chromate stained.
Deliberate
"In fact ... the jaw does contain chromate .... The iron and chromate staining of the Piltdown jaw seems to us to be explicable only as a necessary part of the deliberate matching of the jaw of a modern ape with the mineralised cranial fragments.
"It is now clear (the investigators conclude) that the distinguished palaeontologists and archaeologists who took part in the excavations at Piltdown were the victims of a most elaborate and carefully prepared hoax. Let it be said, however, in exoneration of those who have assumed the Piltdown fragments to belong to a single individual, or who, having examined the original specimens, either regarded the mandible and canine as those of a fossil ape or else assumed (tacitly or explicitly‚ that the problem was not capable of solution on the available evidence, that the faking of the mandible and canine is so extraordinarily skilful, and the perpetration of the hoax seems to have been so entirely unscrupulous and inexplicable, as to find no parallel in the history of palaeontological discovery.
"Lastly, it may be pointed out that the elimination of the Piltdown jaw and teeth from any further consideration clarifies very considerably the problem of human evolution. For it has to be realised that 'Piltdown Man' (Eoanthropus) was actually a most awkward and perplexing element in the fossil record of the Hominidae, being entirely out of conformity both in its strange mixture of morphological characters and its time sequence with all the palaeontological evidence of human evolution available from other parts of the world."
http://www.clarku.edu/~piltdown/map_expose/featur_piltskull_delibfake.html
Skull drawing frauds
DECEPTIVE FOSSIL INTERPRETATIONS OF EVOLUTIONISTS
Before going into the details of the myth of human evolution, we need to mention the propaganda method that has convinced the general public of the idea that half-man half-ape creatures once lived in the past. This propaganda method makes use of "reconstructions" made in reference to fossils. Reconstruction can be explained as drawing a picture or constructing a model of a living thing based on a single bone-sometimes only a fragment-that has been unearthed. The "ape-men" we see in newspapers, magazines, or films are all reconstructions.
Since fossils are usually fragmented and incomplete, any conjecture based on them is likely to be completely speculative. As a matter of fact, the reconstructions (drawings or models) made by the evolutionists based on fossil remains are prepared speculatively precisely to validate the evolutionary thesis. David R. Pilbeam, an eminent anthropologist from Harvard, stresses this fact when he says: "At least in paleoanthropology, data are still so sparse that theory heavily influences interpretations. Theories have, in the past, clearly reflected our current ideologies instead of the actual data".61 Since people are highly affected by visual information, these reconstructions best serve the purpose of evolutionists, which is to convince people that these reconstructed creatures really existed in the past.
Imaginary and Deceptive Drawings
In pictures and reconstructions, evolutionists deliberately give shape to features that do not actually leave any fossil traces, such as the structure of the nose and lips, the shape of the hair, the form of the eyebrows, and other bodily hair so as to support evolution. They also prepare detailed pictures depicting these imaginary creatures walking with their families, hunting, or in other instances of their daily lives. However, these drawings are all figments of the imagination and have no counterpart in the fossil record.
At this point, we have to highlight one particular point: Reconstructions based on bone remains can only reveal the most general characteristics of the creature, since the really distinctive morphological features of any animal are soft tissues which quickly vanish after death. Therefore, due to the speculative nature of the interpretation of the soft tissues, the reconstructed drawings or models become totally dependent on the imagination of the person producing them. Earnst A. Hooten from Harvard University explains the situation like this:
To attempt to restore the soft parts is an even more hazardous undertaking. The lips, the eyes, the ears, and the nasal tip leave no clues on the underlying bony parts. You can with equal facility model on a Neanderthaloid skull the features of a chimpanzee or the lineaments of a philosopher. These alleged restorations of ancient types of man have very little if any scientific value and are likely only to mislead the public… So put not your trust in reconstructions.62
THREE DIFFERENT RECONSTRUCTIONS BASED ON THE SAME SKULL
As a matter of fact, evolutionists invent such "preposterous stories" that they even ascribe different faces to the same skull. For example, the three different reconstructed drawings made for the fossil named Australopithecus robustus (Zinjanthropus), are a famous example of such forgery.
The biased interpretation of fossils and outright fabrication of many imaginary reconstructions are an indication of how frequently evolutionists have recourse to tricks. Yet these seem innocent when compared to the deliberate forgeries that have been perpetrated in the history of evolution.
http://www.evolutiondeceit.com/chapter8.php
