Travis2000LS
So.. Hey guys.. I havent been on much but anyways here is the deal. Ive done some searching and still no cure. Ive Tried replacing my MUCH needed to be replaced Thermostat Housing and bypass tube thinking that would be the source of my Overheating, Well it stopped the leak thats for sure but as for the overheating.. It started again last night. So I was like OH I just need to air bleed a few times and thatll fix her.. Well nope.. I spent a hour air bleeding still no heat at idle and overheating after about 5 miles now.. Ive done replaced the Hydo fan pump actuator which helped alot about 5 months ago. We did a Pressure test on the system about 3 months ago held good pressure giving me no reason to believe the degas bottle is the cause. So I HAVE NO CLUE! All I can think it maybe a clogged heater core would be my cause to this dreaded no heat but I couldnt see how a clogged heater core would cause Overheating? Or could it
Anyways let me know your thoughts. ill post some pics of the new parts on the LS.
THANKS!
Also I couldnt find a guide or write up on how to exactly flush the HEater core on the LS, is it a big job? If so more info on that aswell! Thanks
THANKS!
