dunndarryn
This goes without saying, but that car is absolutely beautiful!
If it helps, Buick put a 3.8L with a turbocharger into a Regal body. That car would stomp a Corvette into the ground. I ran one on the highway once, starting at highway speeds he took off from me like a top fuel dragster. That was with 1980s technology. A modern turbocharged V6 should run at least as well with the better mileage. I'd especially like to see BMW's new electric turbocharger get adopted industry-wide. It eliminates turbo lag completely.
For those that don't know about this, BMW came up with a new turbocharger. They split the drive section from the compression section and installed a clutched electric motor between the two sections. When called for, the clutch opens the drive section and runs up the compression section. This provides instant boost while allowing an unloaded drive section to spin up a lot faster. At some point, the clutch locks the drive section to the compression section and uses the engine to drive the turbo. The whole process only takes a few seconds as the electric section only operates until the engine's RPM is high enough to do the job.
Didn't want to start a new thread since this is XF related haha. I knew that jaguar was bringing AWD to some models in 2013. But what I didn't know is they also have some new engine choices.
You can now get a
2.0 turbocharged engine making 29mpg highway.
Or a
3.0 supercharged engine making 28mpg highway.
I'm sure they are trying to get new buyers with the new AWD and fuel efficient engines, but I'm not sure how I feel about anything less than a V8 in the XF.
