Motts
Has it been done? Is it possible, I wish i woulda known that there was a v6 manual before i got the auto... if so how much?
eL eS said:I got a reply back from the guy in NJ that is already in the parts buying stage. He is interested in forming a group to discuss and plan the project.
cj7man said:The Getrag is a very weak transmission; thats why they didn't come behind V8s...I know by experience (toasted disc) as I'd love to swap out the Getrag...even the shifter is terrible.
Don
Pragmatic,pragmatic said:I don't know. I know the trans is torque limited but I love mine for the following reasons.
1) Great shifter feel. Goes into to gear very smoothly and shifts with precision
2) Well thought out ratios. The gears seems to be properly spaced. My XR4Ti was horrible with that 2nd was way too high and third too low. Replacing that T-9 with a T-5 from a 4cylinder Mustang was a great improvement in ratios. The LS passes well on the highway if shifted to third (~4400 rpm at 65) allowing you to reach ~100 staying in the power band of the engine.
3) Direct top gear. Less noise and less wear on the highway. Basically in fifth no gears are being used just direct connection of input and output shafts.
4) Small and light. It is one of the lightest 5-speeds around.
5) Smooth clutch engagement.
Down sides are it holds too little fluid (IMHO).
Since it is weak it requires frequent fluid changes (every 60,000 miles).
Engine is rough at higher RPMs needed to move the car and weak at low RPMs.
eL eS said:thanks for sharing your expeirences. Sounds like a case of the grass is greeener on the other side. Any recommendations of a shop(s) that do transmission conversions?
Motts said:there is a place in MI, called Unleaded Racing technology, another called first class auto in Taylor, and another in Plymouth MI.... i can get the contact info if you need.
Well first off she would have to stop being a work-a-holic DBA to see how much time it really takes away. Secondly a friend of mine, once pointed out that "it keeps him out of the strip clubs"eL eS said:Thanks for sharing your time with us on LVC. Hey, that is an impressive list of DIY franken-swaps. Your wife either enjoys her free time or is insanely jealous,
eL eS said:Is there a seperate Master Cylinder Resivoir? It has been a while since I looked it up but I thougght I had read that the Clutch and Brake Shared a fuild resivoir
JES_LS said:Well first off she would have to stop being a work-a-holic DBA to see how much time it really takes away. Secondly a friend of mine, once pointed out that "it keeps him out of the strip clubs"
I'll have to check the DVD again, but I thought that it had a separate reservoir. If it does not then we will see what is involved in connecting to the brake res (here maybe a port to drill out or something like that. I know that the MC is available separately from Brake MC.
My wife is strip club friendly
Arnett said:So mine. She loves to go. No better thrill than seeing my old lady stick a dollar in some chicks g-string
